S soori New member Joined Feb 23, 2012 Messages 5 Points 1 Feb 23, 2012 #1 Hello, My GP is two weeks old and is running on stock 15" tires. The ride quality of the car is bumpy on smoother roads. Tried balancing and also interchanging the tires. Can this be the issue with damper, spring or with any other parts?
OP OP S soori New member Joined Feb 23, 2012 Messages 5 Points 1 Feb 23, 2012 #3 Checked the alloys. There are no bends.
L Lal B3N Member Joined Sep 1, 2010 Messages 667 Points 118 Location Cumbria Feb 23, 2012 #4 Could be snapped springs or leaky dampers. Have a good look at the suspension? Some tyres are bumpier than others. What profile are they?
OP OP S soori New member Joined Feb 23, 2012 Messages 5 Points 1 Feb 23, 2012 #5 The tires are stock. 195/60 15 inch. The ride here is bumpier on regular roads. The car drives as if it is crossing a wooden plank every 5 meters
T TallTom Established member Parked in the garage Joined Aug 11, 2009 Messages 971 Points 173 Location Broxbourne, Hertfordshire Feb 23, 2012 #6 Bushes maybe?
OP OP S soori New member Joined Feb 23, 2012 Messages 5 Points 1 Feb 24, 2012 #7 I've dropped the car for inspection in A.S.S . Service personnel is saying this is the first kind of issues they are into and confident that they will fix this by inspecting all the tires, alloys, springs and dampers.
OP OP S soori New member Joined Feb 23, 2012 Messages 5 Points 1 Feb 24, 2012 #8 Today the car returned from inspection with the issue unresolved. To add to the pain the wheel alignment has gone bad again. Thrice the wheel was aligned and the ride is the same. Now am seriously concerned about the issue. Is it a manufacturing defect? Is there any known problem with the suspension or any other parts?
T TallTom Established member Parked in the garage Joined Aug 11, 2009 Messages 971 Points 173 Location Broxbourne, Hertfordshire Feb 24, 2012 #9 Tyre pressures? No idea other than that if the shocks have been checked and they are fine, drop links maybe?
