Thread Tools
Old 11-02-2012   #1
how to fit front foglights with oem switch and oem foglights
i cant find the wiring loom that plugs into these fogs anywhere
A4RON is offline Reply With Quote Quote
Old 11-02-2012   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: how to fit front foglights with oem switch and oem foglights
its not there as there isn't one...
and due to the modern CAN BUS system if you buy a new multi funcion switch bank with the front fog button it wont work (unless your very good with electronics and can build up a flip flop
http://discovercircuits.com/DJ-Circu...-off-latch.htm
but its much easier to wire in yourself to a after market switch
https://www.fiatforum.com/grande-pun...og-lights.html
https://www.fiatforum.com/grande-pun...ml#post2262435
Massive gash
Just a little touch up
Old 11-02-2012   #3
Moderator
Andy Monty's Avatar
this is hte updated diagram ncluding the 2 separate fuses (one for each light)
https://www.fiatforum.com/grande-pun...ml#post2663153
Massive gash
Old 11-02-2012   #4
damm i just spend 50 on a oem switch and a relay
Old 11-02-2012   #5
Moderator
Andy Monty's Avatar
from memory you need to also change the body computer and have it programmed in as well if you try the oem route
it works a bit like this
Push button ---> body computer--(computer checks side lights are on) ---> signal to relay----------> relay powers lights
in older cars the relay signaled by the side light circuit as in my diagram
Just remember to wire everything in well and route the cables safely and securely as car fires due to bad wiring are common ((so common insecure wiring is now an MOT Failure))
Massive gash
Thread Tools
(T) 100HP Front Foglights Thunderbug Panda 15 16-02-2011 23:30
(T) Installing/upgrading with front foglights azureidea2004 Idea 4 22-10-2010 23:19
(T) front foglights / spotlights 1383matt Punto (Mk2/2b) 24 09-06-2009 19:32
(T) Front foglights not working Funkstar De Luxe Barchetta 12 17-01-2009 21:17
(T) The B's front foglights superspotter Barchetta 5 24-03-2007 15:17
