Old 25-01-2012   #1
asr , abs , hill holder help
had my car put on a diagnostics computer and it came up with front right ABS sensor and ring gear fault codes .
tonight i changed the abs sensor started the car and the light came on , i then took it for a drive turned the car off and then on again and all warnings went out. drove it about 10ft and they all pinged on again .
WHERE DO I GO NEXT ????????
brake peddle micro switch i heard is a popular one ?
sabers is offline Reply With Quote Quote
Old 26-01-2012   #2
Quote Originally Posted by sabers View Post
Did you check the toothed trigger ring on the drive shaft was not damaged? I'm not sure which type the punto uses but most cars use a shrink fit metal ring, because the are under constant tension they can be prone to cracking.
If this is the problem the official fix is often a new drive shaft but a bit of delicate welding has been known to save the day.
I suggest the above because it sounds like the diagnostic pointed to a specific cause.
jameshobiecat is offline Reply With Quote Quote
Old 26-01-2012   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: asr , abs , hill holder help
Check the abs plug/ wiring for water ingress and corrosion there have been cases where people have had the front abs loom replaced (do a search I can't easily at the moment I'm on my mobile ) :-)
Old 26-01-2012   #4
This happend to me, i was sitting at a junction pumpin my brakes outa boredom and bam they all came on, luckily engine turned off nd on solved it.
BodyRoxz GPS is offline Reply With Quote Quote
ASR/ESP/Hill Holder Issue skimpy Tech Talk 4 21-12-2013 14:16
(T) Another ESP/ASR/Hill Holder fault! SubSon1C Grande Punto 9 26-02-2012 13:47
(T) ASR/ESP/Hill Holder Issue skimpy Bravo 11 09-04-2011 10:27
(G) abs, eps, asr & hill holder failure on Abarth! duncs04 Grande Punto 23 21-12-2010 18:07
(G) ESP/ASR/Hill-holder alfabarry Panda 5 04-02-2007 16:10
