FIAT Auto Specialist Team
Old 13-01-2012   #1
Boost-Tastic!
DlightSwitch's Avatar
Trader Rating: 1
DlightSwitch has donated!
Star Cannon Champion
Grande Punto Aerial Thread
Hi all,
Just got my new aerial in the post today after the other one was nicked. It's come with 2 screws, a 6mm one and a 5mm one, however neither of them fit. Does anyone know what the thread size (for the hole in the base of the aerial holding bit) should be? I don't want to buy an official aerial just yet in case the base itself is broken
^^ Click for my Members Motors thread ^^
My YouTube Channel!
DlightSwitch is offline Reply With Quote Quote
Old 14-01-2012   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Grande Punto Aerial Thread
They are M5 (5mm) (just been out and wound an M5 nut on mine to check then double checked the base with an M5 plug tap.....
(bit of grease on there but you can see the thread
and your base should look like this
just wonder if its been snapped off and you have been left with the remaining stud off the antenna stuck in the base?
Thanks DlightSwitch thanked for this post
Massive gash
Just a little touch up
Old 14-01-2012   #3
Boost-Tastic!
Trader Rating: 1
Thanks Andy, great idea using an M5 bolt to check. First I had a look in the base, all seemed well so I tried screwing in an M5 bolt I had lying around in the garage, luckily it fitted! You had me worried
By the way the car's not dirty that's the reflection of the artex ceiling in the garage!
Anyway once I took this bolt out, I compared it to the thread I got with the new aerial, and it's smaller than M5, but bigger than M4 So I'll be sending this picture to the seller and asking for a refund.
Moral of the story is don't buy cheap and cheerful
My YouTube Channel!
Old 14-01-2012   #4
Moderator
Andy Monty's Avatar
Quote Originally Posted by DlightSwitch View Post
Is that an M5 thread that goes into the aerial itself in that picture of the stud ?
take a nut wind it onto the M5 bolt and clamp it in a vise and hacksaw your bolt down to the same length file the end you cut the wind the nut over to clean up the threads wind that end into the aerial (so your left with a proper lead in thread to fit into the mast mount blather in grease and fit ) (then if you find reception is crap return it)
PS your car could do with a wash
Massive gash
Old 14-01-2012   #5
Boost-Tastic!
Trader Rating: 1
Quote Originally Posted by Andy Monty View Post
It's an M6 thread that goes in to the aerial otherwise I would have done that. I'll just return it and buy a better one that hopefully fits.
PS Shhh http://www.detailingworld.co.uk/foru...d.php?t=247613
My YouTube Channel!
Old 14-01-2012   #6
Moderator
Andy Monty's Avatar
Already seen it and commented accordingly
dont know if this will be of interest to you
https://www.fiatforum.com/car-care/1...polish-gp.html
Massive gash
Old 14-01-2012   #7
Boost-Tastic!
Trader Rating: 1
Thanks lol..
Yeah I've just had a read of that, quite handy thanks, the GP is a nice car to start on, fairly easy to correct. I'll be trying a different polishing compound next time though, with another write up
Did you do the whole car with a 6" pad? I'm thinking of getting a smaller one for next time.
My YouTube Channel!
Old 14-01-2012   #8
Moderator
Andy Monty's Avatar
No with the DA i mainly used these
http://www.elitecarcare.co.uk/elite-...d.php?cPath=69
I found the larger pads "bogged down" and gave less cut due to the friction created ( i take it you have seen dave KG's DA polishing guide?)
since the DAS 6 Kestral is not a forced rotation put too much pressure on it, It stops rotating
Simple test / guide is to get a marker pen and draw a thick ish line on the radius of the backing plate (ie half way across) you can then see how much force it takes to bog it down and come off the pressure if it happens.....
have a look at this chaps videos as well he is very good at explaining
basicly your buff daddy is a Porta cable
Massive gash
Old 14-01-2012   #9
Boost-Tastic!
Trader Rating: 1
Sorry I've just read further on
My YouTube Channel!
Old 14-01-2012   #10
Boost-Tastic!
Trader Rating: 1
Thanks I'll give those a watch when I get back home, yeah I read Daves guide several times before starting, wouldn't have had the courage to without it!
My YouTube Channel!
(T) snapped thread on aerial robin.janeb@ntlworld.com Multipla 4 02-09-2006 19:01
