im Axle Specialists
Thread Tools
Old 16-11-2011   #1
"Excessive radiator fluid temperature" Anyone know exact problem?
hi guys, over the past few months on the ODD ocassion when starting (usually in the cold) my car has failed first time and said "Excessive radiator fluid temperature" does anyone know the exact problem with this as its getting colder now and it has done in twise 2/3 times today.
Thanks.
andipunto is offline Reply With Quote Quote
Old 16-11-2011   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: "Excessive radiator fluid temperature" Anyone know exact problem?
Get your battery tested
Old 16-11-2011   #3
Elliot Ross has donated!
I have seen on some threads that the excessive temperature is because the car needs a software update. As for the starting problems get your battery tested! If it is a new battery, the alternator is something which seems to be a common problem on these cars.
Elliot Ross is offline Reply With Quote Quote
Old 16-11-2011   #4
Moderator
Andy Monty's Avatar
Quote Originally Posted by andipunto View Post
Thanks.
Quote Originally Posted by Elliot Ross View Post
Elliot read the first post if its only happening when the car is struggling to start its more than likely the battery the software issue was on early cars which where putting that message up on nearly every turn of the key whether the car started ok or not..
the battery been low can cause all sort of issues the Temperature sensor works by return of voltage to the ECU
12V return signal = Cold
9V = warming up
6V= up to temperature
4V= hot
2= overheating...
((not actual voltages but you get the idea))
a degraded battery will drop voltage when loaded (by the starter motor for example) giving a false reading to the cars computer and the subsequent warnings
Massive gash
Just a little touch up
Old 16-11-2011   #5
TBH, the software update was to recalibrate the ECU parameters to help it cope in low voltage conditions, such as a cold start. The small capacity battery fitted to the 1.2/1.4 8v exasperates the problem and makes it more likely to happen as it's already border-line.
Best thing to do is to fit a slightly larger battery (we would tend to fit the larger 1.3 mjet battery), and possibly call in to your Dealer and get them to see if the software upgrade was applicable to your car. If it's well outside of warranty and the car has not been Dealer-maintained, there may be a small labour/diagnostic charge to apply the update.
Thanks Jack1708 thanked for this post
Likes Andy Monty liked this post
D4nny8oy is offline Reply With Quote Quote
Old 16-11-2011   #6
Moderator
Andy Monty's Avatar
I stand corrected
Massive gash
Old 16-11-2011   #7
Greece
I now use an exide 64A 640ah and the "Excessive radiator fluid temperature" still keeps blinking now and then. It is not a battery issue...i've searched A LOT! ECU updates you, name it...nothing...so i learned to live with it.
The starting issue could be the alternator, or the injectors ( do you use a tuning box?).
If it always happens when it is cold, check your glow plugs too.
If nothing from all of these solves the problem, check the fuel you use...
vagosofron is offline Reply With Quote Quote
Old 17-11-2011   #8
Ok thanks loads guys. Something I didn't state was it is a 1.9 mjet if that changes anything?
I'm going to have my battery checked the only other thing I can think to do is check the glow plugs and maybe alternator?
Old 13-12-2011   #9
Australia
I had this issue for months.. finally took it to the dealer. They told me
it was due to the radiator plastic shroud catching on the blades of the radiator. This had caused a fuse to blow. They replaced the fuse and advised me to get a new shroud fitted at $850 AUD, as the fuse would eventually blow again. I thought $850 would buy a hell of a lot of fuses
SimonP is offline Reply With Quote Quote
Old 13-12-2011   #10
Moderator
Andy Monty's Avatar
Quote Originally Posted by SimonP View Post
what for a bit of plastic Take it you mean the fan is catching on the shroud?
I'd be getting a sharp knife out and doing a bit of trimming
Massive gash
Old 15-12-2011   #11
Australia
Quote Originally Posted by Andy Monty View Post
Yeah, the fan is catching on the shroud
Old 15-12-2011   #12
Moderator
Andy Monty's Avatar
is any part of the fans mounting broken?
and when i said get trimming cut the shroud and not the fan blades as it will shake itself to death if you get the blades out of ballance
Massive gash
Old 15-12-2011   #13
Mine does it now and again too mate (1.9mjet). Replaced the battery for a top of the range Varta job, and although it hasn't totally fixed it, it now only happens now and again - maybe 1 in 20 cold starts.
Oddly, it really needs you to wait for the glow plugs to warm up from stone cold leading me to think its at least partially caused by the notoriously-hard-to-reach glow plug on cylinder 1.
Even when it fluffs the start, it always works second time, and as far as I know my rad fan is fine.
HTH!
AndyK is offline Reply With Quote Quote
Old 19-02-2013   #14
I bought my 57 plate 1.25L Grande Punto second hand two days ago, and it's been icy cold here both mornings I have had the car. It started fine first time yesterday morning, but today it took around 5 attempts! First few times I didn't have my foot on the accelerator (my last car was a push to start so it's been a few years since I had to do this!) but as soon as I tried with my foot down it worked ok. The engine management light came on along with the "excessive radiator fluid temp" warning... then disappeared. I'm totally new to Fiat, so any info that may help will be appreciated! Would I be right in saying it could be the same as with the 1.9MJ?
Metalgurrrl is offline Reply With Quote Quote
Old 19-02-2013   #15
Punto.Power has donated!
If car starts fine through now to this evening i would say the battery is on its way out. It was alot colder this morning than it was yesterday.
Or car might have been sitting around before you bought it, so might just need a good charge.
Punto.Power is offline Reply With Quote Quote
Thread Tools
(T) Fiat Stilo 1.2 Electronic FaultThe engine have this "hiccups", then the "city" functi BladeRunner2019 Stilo 11 02-03-2011 19:04
Building media library taking "excessive time" ? Scherzo Blue and Me 3 19-09-2009 22:02
(T) "Brake FLuid Level" Warning kritip Panda 3 07-09-2009 22:27
(G) "Low Brake Fluid" - what does it mean? Ononim Stilo 14 07-09-2009 14:12
