Technical Sticky Gearbox
buzz3994
hi all
hoping you guys can advise, my wife has an 07diesel Punto and this morning gear changes have become very "sticky/thick" (for want of a more technical description), it feels almost like your changing gears through treacle.
i can select gears fine, there is no crunching or grinding but its clearly not right.
Any advice or suggestions would be welcomed.
many thanks
If its an 07 it'll be a grande punto?
an admin will move this to the grande section for you but should use that part of the site from now on :)
Where do you live and what have temps been like? Any evidence of leaking gearbox fluid?
Cheers Bredsticz, sorry yeah it dawned on me i had posted it in the wrong section while i contniued my internet search, so it would be great to have it moved as it is indeed a Grande.
as for location we are in the UK, and we have noticed nothing out of the ordinary. Apart from, i noticed a slightly higher pitched note at the top end of the revs just before she changed gear (this was a couple of days ago, the first time i have been in her car for a while and dont know if this is just a coincidence).
i did wonder if it needed fluid but dont know how to check?
Thanks again
