FIAT Auto Specialist Team
Old 02-08-2011   #1
darthbane666 has donated!
Another MJET gearbox problem?
my mjet is now on 56k and has developed a whining in 3rd and 4th gears. Goes away instantly when changing to any other gear and when placing clutch down.
Is this a sign i need the gearbox refurbing?
darthbane666 is offline Reply With Quote Quote
Old 02-08-2011   #2
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
Re: Another MJET gearbox problem?
sounds just like what mines doing, but mine does it in 2nd 5th and 6th.
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 02-08-2011   #3
yeah mines all quite in all gears apart from 3rd and 4th. Let me know if you find out what the problem is. Looking at getting mine seen to when i go on my hols n 26th
Old 02-08-2011   #4
Is it just me but there seems to be a lot of mjet gear boxes going at the moment. Think i will get the oil level checked on mine next service.
Likes matty seasider liked this post
peter7889 is offline Reply With Quote Quote
Old 12-01-2012   #5
Did you ever find out what it is?
My GF's MJET just started doing this in 3rd and 4th...
doncarlyon is offline Reply With Quote Quote
Old 13-01-2012   #6
Mine has been doing this in 1st and 2nd gear,I got it checked out by a garage and its the bearings on the shaft of the gears so looking at 950 all in for a recon box
guyver is offline Reply With Quote Quote
Old 13-01-2012   #7
Trader Rating: 1
They are one of the worst gearboxes ever like.
You only have to google M32 gearbox issue and look at the 100s of topics on Vauxhall forums.
Mines whining in 6th, bit of movement in 5th and 2nd grinds when driving along yet it still changes gear smoothly. Luckily i found out yesterday i have 2 months warranty left so hopefully warranty will be sorting it out.
I was quoted 395 plus 175 for fitting for all bearings replaced or 750 plus 175 for fitting. If your lucky you could get a 2nd hand one off ebay for 650 but i personally would not risk it.
Lal B3N is offline Reply With Quote Quote
Old 13-01-2012   #8
puntopower!
Trader Rating: 6
My gearbox was replaced under warranty in aug 2011, it's on it's way out gain , been to dealer an they say it's not bad enough to swap yet, needs to get worse lol. So 5 months on a recon!
Old 13-01-2012   #9
Trader Rating: 1
Quote Originally Posted by matty_oakley View Post
lol that is shocking. Hoping they do mine under warranty just need to get it confirmed but i think they might kick off because of its service history.
Old 13-01-2012   #10
puntopower!
Trader Rating: 6
Mine was only done as I have a fiat extended mechanical breakdown warranty. And all servicing has been done at main dealer early, and all warranty work at same garage.
Old 18-01-2012   #11
I had this, in first and second gears. Refurb box, new clutch and dual mass flywheel. 1200. Its a good job these cars look so nice! It had a good run down to bordeaux and back just after and runs like a dream now!
Humble is offline Reply With Quote Quote
Old 18-01-2012   #12
Shropshire_lad has donated!
Just read that these gearbox's upper torque limit is 320 N-m or 236 ft-lbs, no wonder they're not lasting, especially on remapped Mjets.
Shropshire_lad is offline Reply With Quote Quote
Old 19-01-2012   #13
Trader Rating: 1
Quote Originally Posted by Shropshire_lad View Post
I doubt thats true as standard astra vxr makes that and the nurburg edition makes more than that.
Old 19-01-2012   #14
Your bearings are going, will need a refurb or reconditioned gearbox fitted.
Just had mine done, cost 950 on a 56 MJet, with 36000 on the clock.
Dittoo is offline Reply With Quote Quote
Old 20-01-2012   #15
Quote Originally Posted by Lal B3N View Post
Maybe, since read over on VXR that it's rated at 400nm & 295lbft. Although the http://www.fptpowertrain.com website mentions 320nm for the M32 box.
It does seem though from over there that it's tuned car's that are suffering most of the issues which is no surprise.
@ matty_oakley - should have had a milder Angel remap mate, perhaps your boxes would last longer! No wonder yours are failing with torque like that...lol
(T) 1.9 mjet gearbox options Mjet220 Grande Punto 27 18-08-2011 10:26
(T) Panda MJet problem Ricardo sousa Panda 1 04-01-2010 10:25
(T) Mjet GPS gearbox ghsaunders40 Grande Punto 8 02-07-2009 23:52
(T) Mjet problem? ian grant Panda 3 16-11-2008 07:56
(G) MJet Gearbox specs PEZZ175 Grande Punto 23 08-04-2008 22:35
