i'm having trouble finding the wind-in tool to change the rear brakes, does anyone know the part number?
ive called 2 fiat garages and just get told "don't sell tools mate"
they do sell tools, they just can't be a*sed looking them up
I brought one of those 'cube' ones from ebay £4 for home jobs, works not bad, Lazer wind back ones on ebay are £20 ish
Okay after a bit of YouTube research I know understand it a bit more. I've tried turning the piston with long nose pliers and it turns, both ways, but neither way seems to make it come in or out, I've measured it, then done a full turn clockwise, no difference. Same with anticlockwise as well.
Are the threads different? I'm currently doing the rear passenger side
I've tried putting pressure on the piston but it's hard because they're so stiff I need both hands to turn it with the pliers.
I can't use a G Clamp because that doesn't turn.
I've just read that on most cars they need to be turned clockwise, can anyone confirm this?
believe me you need the correct tool, if you just push the piston... it wont work. if you just turn the piston... it won't work!
you need a huge amount of pushing power and turn at the same time, something only a rewind tool can do, the trouble is that the laser tool only turns clockwise...
the passenger side needs an anti-clockwise thread, if you turn it the other way your in trouble!!!!!!!!!!
So what did you end up using in the end then? I suppose there's no point in me going to halfords and buying the laser tool as that would only work for the drivers side which is no use to me, especially now.
I've already learned that it doesn't work, but just to clarify, in a hypothetical situation where i was using pliers, on the passenger side I would need to turn the piston anticlockwise to wind it back in?
Right, that's cheaper than the halfords one, that was £75! Might have to stretch to £55 as long as it means I can use the car this weekend!
I'll not be selling mine though, I reckon I'll definitely need it in the future.
