Am I right in saying that if the bulkhead is rusty/rotten within 30cm of a critical component (in this case, brake servo) it's an MOT failure?
EDIT: From http://www.motuk.com
[FONT=Verdana, Arial, Helvetica, sans-serif]3. Examine the condition of chassis or body structure and panelling around the master cylinder or combined master cylinder/servo mounting.[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]3. Deliberate modification which significantly reduces the original strength, excessive corrosion, severe distortion, a fracture or an inadequate repair of a load bearing member or its supporting structure or panelling within 30cm of the master cylinder/servo mounting, that is, within a ‘prescribed area’, see Appendix C.
[/FONT]
[/FONT]
