Old 14-03-2011   #1
Engine management light / Warning on startup
Hi I have a 1.4 16v GP 58 plate
For a few weeks now every so often when I start the car from cold the engine light would come on and the car would seem really loud/shaky. But turning the engine off/on sorted it
This morning I started the car (hasnt been driven in about 3 days) and the car is really shaky (is this misfiring?) and loud and the engine light starts to flash, and the check engine warning is displayed
When I revved the car it made the engine light stay static I have tryed turning it on/off loads of times and it wont stop!
any ideas on what it could be? im about to go check the sparks
kaosNW is offline Reply With Quote Quote
Old 14-03-2011   #2
Re: Engine management light / Warning on startup
now the engine light is staying on, not flashing as soon as I turn the car on
Old 14-03-2011   #3
Just tried to check the sparks, got the airbox/cover off and the spark plugs seem to be molded together in a rigid plastic casing. Anyone have any idea how to take them out 1 by 1 to test?
The guide on here doesnt have the same spark plug covering?!
Old 14-03-2011   #4
Quote Originally Posted by kaosNW View Post
If you mean there is a coil pack on top of the spark plug then just pull it up. It will be a coil pack if there is an electrical connection that goes in the top with a yellow sort of pin as well. Pull the pin backwards slightly (genlty as well) and then u should be able to remove the electrical connection.
Then pull the coil pack upwards and it should come off, might need a bit of force as there is usually a seal due to the rubber protecting the spark plug from water.
Thanks kaosNW thanked for this post
TallTom is offline Reply With Quote Quote
Old 02-04-2011   #5
Just an update, I managed to get the AA to come out and by the time he got to me the car wasnt shaking/misfiring any more but the engine light was still on. He connected it to his diagnostic computer and it said that there was a misfire on cylinder 4
He said its likely to be the coil pack on the 4th cylinder as the sparks shouldnt have gone so quick and apparently its quite common for a coil pack to go?!?
He reset the error code and the car seemed to be fine, no error/misfire etc. However this week after not driving the car for 3-4 days I started it the other day and the misfire/shaking was back! so I think its linked to the car not being driven
Just wondering if people think that the coil pack seems like the likely culprit? if so is it easy to fix? and any ideas on price?
Thanks!
Old 02-04-2011   #6
It's not that common for coil packs to go. The easiest way to diagnose it is to swap the coil from the affected cylinder to another one and see if the fault now jumps with the coil. If it stays on cylinder 4, then the coil is ok.
D4nny8oy is offline Reply With Quote Quote
Old 02-04-2011   #7
Thanks mate, the thing is after I rev it for abit the engine light goes out and the car seems to run ok, so the misfire is gone! so changing the packs over wont really help
Also it seems it was low on oil..... could this be a side effect of the misfire? or a sign of something more serious? :S
(T) engine management warning light billio61 Punto (Mk2/2b) 2 18-02-2010 21:58
(T) Engine Management Warning Light Madness! Power Steering light Insanity! Moneypenny Punto (Mk2/2b) 11 12-02-2010 14:10
(T) Engine management warning light gary29428 Bravo / Brava 1 07-04-2009 14:17
(T) Engine Management Light/Temp Warning Light Fault bugalugz Punto (Mk2/2b) 1 09-01-2009 23:52
(T) Engine Management warning light psychocandy Punto (Mk2/2b) 9 25-06-2008 12:04
