Technical Brake bleed sequence?
East Yorkshire
Any one know of the correct bleed sequence for the Gp?
From what I gather you bleed the system diagonally and start with the brake with the longest run so with the abs modulator to the left of the engine bay am I right to assume to start with the back right then front left then back left then front right then finishing with the clutch?
I was thinking about doing this next month and fitting new pads.
Is there any new brake fluid you reccomend?!
DOT 4 fluid from a new sealed bottle which has been left to stand for several hours before using DO NOT SHAKE THE BOTTLE leaving it to stand allows any air that has got into the fluid during transit to rise and escape
The 1.2 uses 8mm on front nipple and 7mm on slave
I got a one man bleed let a while ago and it was a slack fit as the nipples are very small and for the rear I had to trim the locking plastic plate to fit past the pipe union
all i used was the appropriate sized spanners and a easy bleed one man bleed kit
http://www.jhmbuttco.com/acatalog/info_TBT0530.html
the bit of plastic on the hose is used to "lock" the hose to the nipple it has two sizes so you stuff the hose end through the best fitting hole for your nipple slide the hose on then pull the plastic down over the nipple to secure it in place.
due to the short nipples i had to loosen the nipples with a ring spanner than use a standard open spanner to open and close them during bleeding as wouldn't get the hose on
then snugged them back down with the ring spanner to avoid damaging the nipples after i removed the bleed kit
Re: Brake bleed sequence for Grande Punto?
I have the ELearn software which I understand is the Fiat Workshop Manual. It states that the bleed sequence is
any front calliper
then the other
then any rear calliper
and then the other
This is strange in that no thought is given to bleeding the calliper furthest away from the master cylinder.
Have any of you information as to the manufacturer's sequence being different from this?
It ("the Sequence") doesn't matter much if you do scheduled maintenance, simple DIY brake fluid change. So don't worry (but in case of ABS it's the closest to pump, so front goes first, then rear).
It can be important when entire system is drained (brand new ABS unit, all hoses/piping new etc.). But then, the sequence itself is not enough.
