Thread Tools
Old 22-02-2011   #1
Mjet coolant drain points
My mjet130 is 5 years old now so time to change the coolant, can some body please tell me the locations of the drain points on the radiator ? I been messing with the car for about an hour today day but hasn't spotted them, i am assuming that the intercooler is on the bottom of the rad coz that seems to get in the way. Also is it worth useing a coolant flush first before replacing the liquid ?
Any help would be appresheated, pictures would be even better
peter7889 is offline Reply With Quote Quote
Old 23-02-2011   #2
Re: Mjet coolant drain points
Come on some body must have changed there own coolant on an mjet
Old 23-02-2011   #3
just remove the bottom radiator hose there isn't a drain plug, or you could do it the easy way without the need to bleed the system of air. remove the small pipe to the header tank (be careful not to snap off the union on the header), push a length of washer pipe into the pipe you just removed and put the other end in a suitable container (old washing up bowl), remove the radiator cap and start the engine just top up the coolant as it drains.
Thanks peter7889 thanked for this post
fiatTech199 is offline Reply With Quote Quote
Old 23-02-2011   #4
Thanks alot i like the idea, much simpler than bleeding.
Old 24-02-2011   #5
we do it in the garage all the time saves on time and messing about
Old 24-02-2011   #6
Is it worth putting a coolant flush throught the system before i change the coolant ? As the old stuff has been in there for 5 years now.
Old 25-02-2011   #7
i wouldn't bother, if you do you will have to drop all the coolant from the bottom radiator hose you dont want that stuff hanging around in your system
Old 26-02-2011   #8
I have just checked my manual and according to that the 1.9mjet has got 6.3L coolant in it. 3 litres of red paraflu is going to cost a fortune to buy, i am very tempted to get the car plan equivalant that is only about 20 for 5 L.
Old 26-02-2011   #9
depends on its freezing point and if your bothered about using fiat products. but most good quality antifreeze is fine to use
Old 26-02-2011   #10
I have decided to order 5L of comma xstream g30 coolant it is recomended for use on audi, vw and porsche so it must be half decent stuff. It must be better than what is in there now anyway
Thanks for your help on this, i am suprised how little information there is on the forum for coolant changes i am assumming people just don't bother.
Thread Tools
(T) How do I drain the coolant system on my ElX? SeanoPunto Punto (Mk2/2b) 4 04-01-2011 14:47
(T) Wet Footwell problem, where are the drain points? xtinkerbellx Punto (Mk2/2b) 7 29-11-2009 22:39
(G) Engine Block Coolant Drain Plug flare 124 Spider (Classic) 2 31-08-2009 14:23
(G) [Brava] How to drain the coolant soulkeepe Bravo / Brava 4 17-07-2009 16:26
(T) Gearbox drain & fill points 77jm Punto (Mk1) 3 04-07-2009 22:20
