Styling fitting cupra splitter.
dirky90
i have read most of the threads but cant find the answer, when trimming the centre tabs did people trim it flush or leave about an inch of the tabs.
cheers
can you remember how much was left then, it could work with both an inch or flush.
where did you put the first screws for the centre, the lower middle part or where there are two layers?
cheers
i fitted mine today
to be honest each car is different and the way you fit them is different. i had to cut different amounts off each side. you have to offer it up and cut what you have to and then offer it up again and so on
looks good mate, i probably finished mine at the same time you posted.
did you put it on axel stands?
