Thread Tools
Old 11-01-2011   #1
.:Schalke 04:.
boddahchris has donated!
Hissing from engine?
i've just noticed a constant hiss coming from my engine, it only starts once the engine has warmed up but then continues as long as the engine is running, it sounds like it is coming from under the plastic engine cover, i'm gonna take it to the garage next week but if anyone has any idea whats wrong with it i could do with the info?
boddahchris is offline Reply With Quote Quote
Old 11-01-2011   #2
Re: Hissing from engine?
Snakes alive!
If you have a coolant leak you'd probably see steam, or fluid leaking. anything under the car? Are all the caps on tight?
Does the temp gauge climb above half-way?
Mozarella is offline Reply With Quote Quote
Old 11-01-2011   #3
.:Schalke 04:.
Quote Originally Posted by Mozarella View Post
Snakes alive!
nothing but a hiss, no leaks and dials seem to be working fine?
Old 11-01-2011   #4
willeywilson has donated!
spark plugs all in ok? manifold tightened up properly or cracked. I have seen my brothers exhaust manifold, where the flexi joins the downpipe, to be leaking and smoking quite badly on full throttle
JTDM - Jess The Diesel Muncher
Click For Members Motor
willeywilson is offline Reply With Quote Quote
Old 12-01-2011   #5
Inlet? Airbox leak/hose?
Gollum trapped in air filter? Jeepers. What can this be?
Old 12-01-2011   #6
Check the crank case breather hose.....
Mr Lovedog is offline Reply With Quote Quote
Thread Tools
(G) Hissing reaper1988 Bravo / Brava 9 17-05-2007 02:51
(G) Hissing Noise From Mk1 Engine YeTeP Punto (Mk1) 11 08-02-2007 00:49
(G) Gearbox oil change or not ?? hissing noise from engine when clutch not pressed!!!! robinhood232 Punto (Mk2/2b) 3 02-11-2006 14:43
(G) Loud hissing sound from bottom of the engine mavericke Punto (Mk2/2b) 16 01-05-2006 11:44
(T) Engine hissing and miss firing la16284 Punto (Mk1) 6 26-06-2004 03:14
