Not something ive done before. If I was to look at adjusting the front camber myself, how would i go about it? Something to do with the two bolts holding the strut to the the hub? Cheers
You will need camber adjusting bolts i think. Eibach might do a set but i havent checked. If there arent any listed for the GP maybe worth trying Corsa D bolts?
good point this, i think in the future i will remove the strut bolts. All we need is the diamter and the thread pitch then am sure eibach could match it up.
Let's hope someone could confirm the corsa B will work!
I tried ringing venom the other day there not too far from me. But no answer... They must be shut right through till Tuesday. But I will be finding out if the VXR camber bolts work on ours. If so... group buy?
