Thread Tools
Old 13-11-2010   #1
Greece
Gas tank filter in the tank!
For the last 2 days i heard a strange noise coming from the back of the car like something was moving when i used the brake. Five minutes ago i found out what that was...
When i went for a gas refill 2 days ago the person who worked there must have pushed the hose harder and the filter is now in my tank floating and hiting the tanks walls. What can i do now? And most important...how can i kill the gas man since i can't prove that he damaged my car?
vagosofron is offline Reply With Quote Quote
Old 13-11-2010   #2
deanm1 has donated!
Re: Gas tank filter in the tank!
Poss drop the tank and see if you can get it out that way other than that unsure other than replace the tank it's self but am sure that might be a little drastic.
Thanks vagosofron thanked for this post
deanm1 is offline Reply With Quote Quote
Old 13-11-2010   #3
Greece
That's what i'm thinking but i don't know how big is the hole under the tank in order to take the filter out...
Old 13-11-2010   #4
deanm1 has donated!
I am unsure mate its somthing I have never had to do on a GP sorry mate there may be something in the guides section that might help, or you could ring your local fiat dealer on Monday I am sure one of there guy's would give you some advice.
Old 13-11-2010   #5
Greece
Yeah i guess...thanks anyway!
Old 14-11-2010   #6
Don't follow me, I'm lost
SeanW's Avatar
SeanW has donated!
Do you access the fuel pump/sender unit via a panel under the rear seats? If so, take those out and see if it's possible to remove the offending item that way? (maybe with a long hook of some description? old coat hanger?
SeanW is offline Reply With Quote Quote
Old 14-11-2010   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
i'm lost as to how the pump can reach the filter?
Old 14-11-2010   #8
Greece
I don't know either, but somehow it is floating in my tank...
Old 14-11-2010   #9
Greece
Here is an image of it...
[IMG][/IMG]
Old 14-11-2010   #10
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
do you mean the anti syphon?
Old 14-11-2010   #11
Greece
no i mean a little green filter missing...
Old 14-11-2010   #12
It's not a filter- it's an anti syphon flap device. The only filter is directly attached to the pump in the tank.
You can remove the filler neck and let the broken pieces fall-out to stop the rattling, but the only 'fix' is a new filler neck.
D4nny8oy is offline Reply With Quote Quote
Old 15-11-2010   #13
bluepunto2 has donated!
next time you need petrol (its not gas here in the uk, gas is what comes out of your bum after a hot curry etc) get out of your car and fill it yourself, this way if you break anything on your car
A: you know what you have broken,
B: if you break it, its your fault
C: there could be a chance some clown will put diesel into your car and really make a mess of it...
2007 "56" Grande Punto Dynamic 1.2
4653
bluepunto2 is offline Reply With Quote Quote
Old 15-11-2010   #14
Moderator
Andy Monty's Avatar
Andy Monty has donated!
strangely though bluepunto many filling staions provide the filling as part of the service it used to be the same here
its not an anti-syphon device more of an earth flap to make metallic contact with the filling gun to prevent electrostatic discharge causing a spark and the subsequent ignition of fuel vapours
Massive gash
Just a little touch up
Old 16-11-2010   #15
Greece
Quote Quote:
What Andy Monty said above with the difference that over here ALL filling stations fill you up themselves. There are 2 or 3 stations where i live that have 24hr self service...
Thread Tools
(T) gas tank removal dbith57 X1/9 2 25-01-2010 17:49
(G) uno 45S gas tank cap wont open adamot Uno 1 28-10-2009 08:27
(T) How do i empty the gas tank on my fiorino Jallizz Fiorino (Mk1 / Mk2) 10 09-06-2006 23:33
(T) Gas tank ID Kickstarter 124 Spider (Classic) 3 12-05-2006 05:23
(T) Removing Gas Tank Warp X1/9 3 02-08-2004 01:42
