I had a problem with the fan not running. I tested to make sure i had 12 Volts to the motor and then took the motor/fan out. I then stripped and cleaned it with electrical cleaner. Loads of dirt came out, then i connected the multi plug back up and tried it whilst i held it in my hand. It's been ok since and that was 4 weeks ago.
Not that I am aware of, just a standard fitted radio that has always been there. Its a 2007 reg grande punto I have at present. Struggling to locate the exact fuse (What will the description be in the hand book for the blowers/heaters? Really is a pain in the butt. Really want it fixed ASAP.
I've got exactly same problem as you... same car as well... I've looked at the handbook several times at the fuses section, there isn't 1 description that refers to heaters or blowers. But saying that there was a clicking noise for a few weeks when heaters were switched on so I'm thinking maybe heater motor has packed up. Don't really wanna take this to garage as bet get ripped off!!
Any1 out there know which fuse number it is and in which fuse compartment??? my last thing to try as cable underneath in passenger footwell is definately connected ok! Any help much appreciated!
