Thread Tools
Old 09-11-2010   #31
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: 1.9 Mjet engine failure
Quote Originally Posted by peter7889 View Post
The car is 4 years old in march next year but it only covered 38k miles, can i leave it a few more years ?
Only if you don't mind forking most of the price for a new engine if the belt breaks .
Age is as bad for rubber belts than wear itself as the rubber breaks down and starts to crack (similar to a old car tyre)
ChrisUK is offline Reply With Quote Quote
Old 09-11-2010   #32
Mmmh new car :D
jostheboss's Avatar
jostheboss has donated!
If the cambelt had gone, would you be able to turn the engine over?
www.carlin.co.uk
Fiat Grande Punto 1.9 Sporting Exotica Red needs lowering!!
jostheboss is offline Reply With Quote Quote
Old 09-11-2010   #33
Quote Originally Posted by jostheboss View Post
If it had already mashed all the valves out of the way, yes.
Takes 5 mins to undo a few of the cambelt cover screws enough to see if the lot is turning when the crank is spun.
D4nny8oy is offline Reply With Quote Quote
Old 10-11-2010   #34
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Quote Originally Posted by D4nny8oy View Post
If cambelt has gone & the pistons have cleared themselves a path through the debris of mushed valves, the starter would still turn the crankshaft over yes. It might stil sound odd though, with periodic piston - valve contact... nasty...
But then it might be OK... Whip the cover off the old girl & see what can be found, if the belt is in one piece you can either see that directly or crank it with the valve cover off & see if the camshaft turns.
Good luck, hope it's a minor thing... Just dont keep us in suspense damn ya!
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 10-11-2010   #35
Mmmh new car :D
jostheboss's Avatar
I removed the cambelt cover today and its fine, and after charging the battery a little bit via jump leads it managed to turn over, but made a nasty noise.
I've taken it to fiat for diagnostics, think its worth paying 30ish to find out the exact fault, then I can either replace the engine myself, or get them to fix whatever it happens to be.
www.carlin.co.uk
Old 10-11-2010   #36
Shauncorwyn has donated!
Did it start and drive?
What kind of noise?
Shauncorwyn is offline Reply With Quote Quote
Old 10-11-2010   #37
Mmmh new car :D
jostheboss's Avatar
Like a grinding noise, like a bent crank grinding against a main bearing....
And no, it didnt fire up...
www.carlin.co.uk
Old 10-11-2010   #38
Makes me wonder if it's suffered oil starvation during the track session, and it's manifested itself later on as the shells have worn through and heat seized.
Sadly this is all speculation without pulling it apart...
Old 11-11-2010   #39
that thought had crossed my mind, maybe sustained hard cornering had caused the oil to miss the uptake, and caused some damage that has only now showed later...
www.sharkrider.co.uk Current car: red GP sporting, 1.9 (165bhp and 314 lbs/ft )
last car: fabia vRS, 160bhp, 80k by the time I'd finished with it. Gone, but not forgotten.
sharkrider is offline Reply With Quote Quote
Old 11-11-2010   #40
jostheboss what has the garage said?
1.8Stilo is offline Reply With Quote Quote
Old 11-11-2010   #41
Mmmh new car :D
jostheboss's Avatar
They removed the glow plugs, and saw that Mr Piston had made sweet love to Miss Valve....
Definitely needs a new engine.
I just got off the phone to Fiat UK who are looking into it to see if they can help in any way. I have to say that everyone from Fiat seems suprised and they're all very helpful.
Will have to wait and see what happens. I'm in China as from Sunday so wont have anymore updates till I get back.
Lets hope Fiat cough up some dollar!
www.carlin.co.uk
Old 11-11-2010   #42
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
I'm pretty damn sure that can only happen if some unfortunate event has taken place that changed the valve timing, such as a tooth or two coming off the timing belt or the tension of the belt being lost due to some other failure. I hope thay dont enforce the 4 year timing belt change rule rigidly Jos.
Anyway enjoy China... fun place I'm told
Old 11-11-2010   #43
Mmmh new car :D
jostheboss's Avatar
Hope it goes better than last year!
Look out for our drivers - Ricciardo, Hartley and Chilton - all got taken out on the first lap!
www.carlin.co.uk
Old 11-11-2010   #44
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
http://www.youtube.com/watch?v=1V26b5aecQs
Cracking stuff... dead jealous now!!
Old 11-11-2010   #45
New engine, my arse!
Pistons won't be damaged as the valves are made of weaker material. Worst-case scenario is a new head, valves, buckets, shims, etc. Like Ffoxy said- for piston to valve contact, the belt can't still be timed right.
Thread Tools
(T) Instrument pod failure MJET 130 skodaman Grande Punto 6 03-10-2010 11:25
(G) new 1.3 MJet 95 HP engine prices csabaszalma 500 23 26-11-2009 19:46
(G) new mjet engine porlus Bravo 4 09-10-2008 22:58
(T) Engine Control System Failure and Power Steering Failure oc99 Punto (Mk2/2b) 2 18-05-2008 15:54
(G) ABS failure EBD Failure Switch off engine Call Garage Handbrake lamp on SillyBilly Multipla 0 15-03-2008 22:16
