Old 01-11-2010   #1
Coolent Bleeding?
HI,
how many bleed screws are on the grande punto 1.3 mjet?
I have found the one at the top left on the radiator but can not see one anywere else??
if possible could you show a picture of were the other ones are??. I think there should be on at the rear behind the engine block??
thanks
Grim_Evil is offline Reply With Quote Quote
Old 01-11-2010   #2
Shauncorwyn has donated!
Re: Coolent Bleeding?
DRAINING THE SYSTEM- With the engine cold, undo the expansion reservoir cap.
- Position a suitable container for collecting the coolant.
- Open the drain tap located in the lower left part of the radiator.
- Open the bleed screw on the upper part of the radiator, right side.
FILLING THE SYSTEM- Close the drain tap and keep the bleed screw open.
- Fill the circuit with the specified fluid through the expansion reservoir filler fitting until fluid emerges through the bleed screw.
- Close the bleed screw.
- Top up the fluid again until the tank level is up to the MAX mark.
- Fit and tighten the expansion tank cap fully.
- Start up the engine and let it idle for about 2 minutes.
- Remove the air from the circuit by pumping the accelerator regularly and gradually (every 30 secs) up to a speed of around 3000 rpm. This operation should be carried out until the thermostat opens and the fan switches on and off at least 3 times. During this operation keep the climate control system switched off to prevent the fan from coming on for reasons unconnected to the heating of the coolant. If there is a noticeable drop in the level in the tank below the MIN reference during this stage, let the engine idle and open the cap very carefully, topping up the fluid to the MAX level, then close the cap fully and remove all the air from the system.
- Then switch off the engine and leave it to cool down.
- If necessary, top up with the specified fluid to the MAX notch.
- At the end of the above operations, make sure that the amount of fluid introduced into the system is at least equal to the amount collected during the draining stage.
Shauncorwyn is offline Reply With Quote Quote
Old 02-11-2010   #3
thanks.
Hopfully now all sorted(airlock)
Old 02-02-2011   #4
Quote Originally Posted by Shauncorwyn View Post
Sorry to open an old thread but is are the bleed points the same on the 1.9 mjet rad ?
peter7889 is offline Reply With Quote Quote
Old 03-02-2011   #5
bump Any one ? I am very reluctant to take it to a garage to change my coolant.
Old 09-03-2013   #6
I have an 06 Grande Punto DIESEL. I have gurgling and sloshing sounds coming from the passenger dashboard area. From searching, I think I have air in the coolant system and need to bleed it. However... I can't find ANY taps or bleed screws on my radiator/system to bleed the coolant. Can someone post some photos of where they are?
Someone in the Punto forum suggested it might be self bleeding system. If that't the case, how do I bleed it? Or is it a case of unplugging the lower rad hose and renewing coolant?
philbrian is offline Reply With Quote Quote
(G) What coolent do you use? MadMan0 Punto (Mk1) 3 07-06-2010 16:47
(G) Coolent loss FRESTER Multipla 0 30-12-2009 12:25
radiator coolent veltsy Newbie Central 2 13-08-2008 20:54
(T) coolent temp sensor 5577rob Punto (Mk2/2b) 3 24-05-2006 00:23
(T) Coolent Silver_Sei Cinquecento / Seicento 2 14-09-2003 04:32
