Hi All,
Thinking of getting aftermarket replacement pads and discs for when they need replacing to give the car a slightly different and more aggressive look. The discs have a large lip on them atm but I have not yet checked the pads but the car is on around 24,000 now.
I wanted to check to see if these will be suitable, as all of the specs I have read for the discs say the follow for brake specs
Brakes
http://www.europerformance.co.uk/pag...duct=555597620 - Rear Disc yet its 264 x 10 but above it states they are 264 x 11, I know that thats thickness, but will it make a big difference?
Also after some decent Pads thinking that these green stuff should be good, but are there any other pads that are recommended
http://www.ebcbrakesdirect.com/car/p...+%282007%2D%29
Thanks for any advice
Tom
Had posted in the Abarth section but no interest that I can see.....
Brakes
- Fixed front calliper: Brembo M4×40, dual piston
- Ventilated front brake disc ø 305 mm x 28 mm
- Rear calliper with piston ø 54 mm
- Rear brake disc ø 264 mm x 11 mm
Tom
