To be honest, they were doing it since i bought the car. The brakes are crap and i have to apply a lot of pressure - just getting progressively worse. You get what you pay for I guess!
If you have been abusing it and the pedal has pretty much touched the floor when you have been braking, you have most probably boiled your brake fluid in the calipers, so if you do a full brake fluid change when you replace the pads then you should see much improved braking. Once brake fluid has been boiled its pretty crap to brake with
