Tuning remap and bravo turbo HELP
course its going to make a difference there is nothing wasted as the pipe conect is blocked... i have just never seen this much increase of a dump valve before rolling roaded shows the difference
What? None of that makes sense? Nothing is wasted? lol Tjets have a recirc valve as standard. This dumps it back into the induction which can help the turbo spool up faster. Putting an atmospheric dump valve in makes 0 difference to power on a standard turbo even with remap as instead of putting it back into the induction you are just putting it into the atmosphere. So i really dont know what you mean by nothing is wasted.
i am completely confused now .... lets change the subject... is a bravo turbo going to help me in this situation and have you had your car mapped an where is so and what are the readings
Okay, explain what you meant by nothing is wasted now you have a dump valve on? Do you actually know how they work and what there purpose is? If you read the thread you will see ive already told you what my car made on a rolling road after remap.
If your mapper is managing to get it to peak at 200bhp so early i would change mappers personally. You should not get anywhere near this on a standard turbo. If you put an abarth/bravo 150 turbo on then you should be around the 180bhp mark or higher.
no i dont really i am going on what someone has told me so i am fighting a loosing battle i have a brife understanding not massive but it was jsut what the rolling road showed as well .... will the turbo just replace the old turbo?
thats the story all along i am gaining of the map 120nm of tourqe and around 60hp peaking at around 3000 rpm its has been the story from the first post.. i am only going on what i have been told and what the rolling road shows .. so no need to be gettin arsey on here i havent done anything to offend you i appricate your help and advice but no need with the attitude
so from this i have been told a load of **** ...(not from you guys) and i need to get a bravo turbo and have it remapped ... any recomendations?
