I have a Grande Punto Dyn Sport 08 and am having problems with the brakes.
If I hit the pedal too hard the pedal doesn't initially depress and there seems to be a delay before the car breaks. It's most noticable at higher speeds when doing a sudden (rather than gentle) brake - the pedal becomes very firm and you have to apply more pressure than you would normally. It doesn't seem to depress as far and there is definitely a delay before the car decellerates.
Another issue I'm experiencing is a hissing sound coming from the drivers side of the car (seems to be coming from the far right of the car). It stops whilst accelerating - not sure if the issues are connected?
I took the car into the garage and they couldn't find any problems with the brakes (I hadn't noticed the hissing at the time so didn't mention this). The car is still in warranty but they charged me £65 for the brake check as it's a wear and tear item. The problem seems to be more to do with the pedal though...
Has anyone else experienced these issues or can anyone hazzard a guess at what could cause these problems? I'm going to take it back to the garage again but want to be more prepared this time!
Thanks in advance!
Alex
Thanks in advance!
Alex
