Technical Folding rear seat popped out
Riikkaarrd
Folded down the rear seat and one of the hinges popped out. I was wondering how do you put it back in, I tried using a screw driver to push spring in but was not working.
It is not a split rear seat.
Thanks for any help you can give.
Riikkaarrd
i remove mine all the time, its quite easy, just use a flat head screwdriver or anything that may work and pull back the spring, it should come back with the cap at the to allowing the seat to slot back in, if the spring isnt pulled back enough it wont slot in, so make sure you pull it back far enough,
Thanks for the advice got it back in this morning without any trouble after giving up yesterday after several tries. Just me being a douche and not pulling it back far enough ;)
Must be the time of year.... Mines just done it as well.
Screw driver blade worked fine, after the first attempt that nearly took the end off a finger.
