Tuning to decat or not to decat...
Wills_1990
Weare
Hey Guys, just wanted to see what people thought about decatting the 1.9 mjet, anyone done it and if so does the cat have any type of electrical sensors e.g. oxygen sensor going to it, any advice would be much appreciated
cheeers :D
i have done it on my 1.9 mjet, there are no sensors that are affected from removing the cat. Turbo spools up faster and few bhp gains are as a result. Still passes emissions due to DPF on downpipe (know this becuase had mot last week) removal of DPF will effect emissions light though.
Yer i heard that about the turbo, ahh thats good then that was gonna be my next question with the emissions, so if i did a set up with taking the cat out the mid box and replacing both with piping would that still be ok on emissions? and have you kept the standard back box on it?
Describe the bit you have removed?
The cat has a Lambda sensor in and is in the turbo down pipe.
actually thinking about it, i think the cat is in the downpipe, not under the car, if its the part i am thinking of the part you have removed is just an extra silencer.
I thought the CAT on the T-jet & M-jet was connected to the manifold? I was told this when the exhaust place had a look at it?
Reece
seems to be some confusion, i had my cat taken out like i said earlier along with my mid silencer box or what ever you wanna call it. The cat was after the flexipipe but before silencer.
I was told the downpipe either contains a DPF or a pre CAT, mine has DPF here but im getting that took out soon.
Is this correct?
according to Eper the box in the downpipe is a silencer catalized, and the box after the flexi pipe is a ANTIPARTICUL.FILT. which by my translation would mean DPF (diesel particulate filter)
Is this correct?
According to Eper, there does seem to be 2. The second CAT is not monitered by Lambda sensors and therefore would have little difference on engine management apart from a drop in back pressure. You have removed a silencer by the looks of it
The DPF will be a little different, and it will require some work on the ECU unless you want the EML on all the time.
I have a straight through pipe after the flexi-pipe and i gutted the pre-cat from the picture above on the right. No ECU light came on because the sonsor is before the cat.
It's not very loud, but you definately feel a difference.
You mean you've opened it, destroyed the inner contents and then welded it back up?
