Technical brake disc
i have just had a service 32K and i have been told i need new brakes and pads but i have had a look at EBC brakes and they say they are 22mm is this the same for the oem brakes because it says they have 20.7mm left do i really need new discs??:confused:
I'm on 64k miles now on OE discs, depends on use but there can be some "oddities" when a dealer checks brakes.
Personally I'd guess your discs are fine... unless thay are warped of course, but then you'd feel that as a surging effect when braking gently.
Does anybody know which disc i need from ebc for the 100hp?
They dont have an option for it on the website, but i have been told, it has the same brakes as a punto.
Tah
It may be better, but when i used the search function, i saw this thread and didnt realise it was in the punto section,
... i have had a look at EBC brakes and they say they are 22mm is this the same for the oem brakes because it says they have 20.7mm left do i really need new discs? ...
I think the 1.3 75hp disc is a Brembo 09.5843.34 with a max/min of 22/20mm – then at 20.7mm you’ve used about 2/3rds of the lifespan. But check your model & disc drawing for yourself at …
http://www.brembo.com/ENG/catalogo_AM/2008/index.html
… then select [English] from the drop down [Europe & International Catalogue] menu.
For pricing check-out …
http://www.bremboshop.co.uk/
