Well my first post and a sadly to ask some advice on a few problems with my wife's 09 plate 1.4 T Jet Sporting 5 door.
1. Smell of petrol/oil - especially when doing a warm start. Car has been back to Fiat for this, and no leak has been found. Smell is quite strong, and I noticed today the dipstick has a similar smell. I see elsewhere on this forum it could be the breather pipe, am I right?
2. Sound of water in tailgate when opening it - presume a seal is broken, again from info I've seen on here. Also notice water on parcel shelf when this happens.
3. Condensation in fog light - presumably a new one is required?
4. CD player - keeps jumping on certain CDs then spits them out. Any fix or does it need a new one?
5. B&M and lack of compatibility with ipod - adapter needed - presume this will work fine if bought, don't want to waste ~£70
6. Sometimes B&M doesn't display the names from calls, only the number, no pattern as to when this happens.
7. Trim under windscreen coming up on drivers side - again new part needed from details on here????
8. Panel gaps you can drive a bus through, but I guess this is all part of buying a Fiat!!!
The car has been into Fiat for some of these problems and all the car software has been updated.
Thanks for your help.
