right im fitting my led side lights ive read the guied but from what i gather does the resistor go from red and yellow across to black and violet or do i fit the resitor to red and yellow and one to blackad violet???
hi i have read the guides buti dot under stand how you wire them in for my led side lights is it red and yellow tored and yellow or is it red and yellow toblack and violet?
i had a prob with that before....what i did is went direct to the side lights, instead of the main light stock....just remove the rubber cover behind the head lights, remove the side light from its socket, then connect the resistor to the 2 wires.
