Well i tried and failed (and almost torched my car in the process) so i'm gonna ring around to have one professionally fitted, any idea how much i should be looking to pay before i ring around?
no sounds to me like a faulty unit rather than your wiring (assuming you wired it up live to live negative to negative and didn't get them mixed up)
i'd have stuffed a fuse in line too
I'm guessing it should be red/white for positive and black for negative, then [/b]yellow is the ignition switch... but I guess that then would mean the secondary socket that I'm adding will be permanently on?
cheers, you were partly correct.
its actually bottom left, just needs a screwdriver sliding behind it and prising out towards the right.
now I've got that done I have another question. The original cigarette socket has 3 wires going into it, black, red/white and yellow/black. Any idea which I should be wiring up to the two (positive and negative) terminals on the new socket??
I'm guessing it should be red/white for positive and black for negative, then yellow is the ignition switch... but I guess that then would mean the secondary socket that I'm adding will be permanently on?
Thanks for that but I had already done the arm-up-the-centre-console-blindly-feeling-around-for-a-loose-wire thing
And I can confirm that the new one is indeed switched with the ignition.
