- Apr 26, 2007
- 13,617
- 2,161
itz mint at dis tyme ov da yr az u cn plow da feelds enit.
Yer man... tractors raaawk, evil weazel is smogtastic & the noize is baaad!
Mine failed at 60k and was replaced under warrenty. I always had a "stutter" on throttle responce when warming up after that... just had my 90k service done, and added the swirl gasket, and it has cured my stutter.... hopefully it will help this EGR valve last longer.
Where does this swirl gasket sit.
I had my egr changed 1 year ago (fiat recon under warranty) after approx 30k.
Now getting the same symtons at 55k. Cleaned my egr last weekend but hardly made a difference.
I have now ordered from the bay the saab egr ( hope it fits - certainly looks the same).
So back to my original question where does the swirl gasket sit. There are 3 possibilities in my opinion.
1 flex pipe attatched to engine (top area)
2 Flex pipe attatched to egr
3 Rigid pipe attatched to engine (lower area)
would be gratefull if anyone can help with this and what is the function of it (does it help keep egr clean).
I would also like to add that the user guide for cleaning the egr was excellent to explain how to remove it.
Did you find & clean the 2 hidden side venturi?
To be honest do not remember seeing or cleaning them - did you get any pictures.
I have ordered the part now so will be stripping down the old again when i take it back off so if it is the venturi's will hopefully mean i will then carry a spare for the future.
I had trouble getting the EGR off , so took it to the guy up the road i swear by, he also sorted my dads saab, everything was cleared out and the car ran the best it had since i got it, unfortunetly i dont know if the side Venturi was checked, though if i have trouble with it again i'm thinking of blocking it off as it seems to cause less hasle that route
W
It fits as long as you bought the one off the Saab 120 TID engine
I've re-assembled it now Shaun, no pics sorry, but where the EGR splits on the metal side, look at the edges of the EGR body & probe around, I used a plastic cable tie & found the 2 venturi, about half an inch wide, & opposite each other, just under the lip. The cable tie I used just about slid down the venturi almost the full length of the cast body, they must be there for something so should be clear!
Yeah hope it is the right one - i think i bought same as you as there is an Adam asking on ebay whether the saab one fits the fiat - i assume thats you.
shocked i was, and he has told me this the egr valve part no.55215032 is the same on the vauxhal CDTI engine and the sabb engine its built by fiat and sent to them, so if you go to a vauxhal garage and ask for the same part number they will give you the same part all shiny and new! with a vauxhal badge on it for 90 quid instead of 260 as quoted by my local fiat garage!
