Yeah,only cams are different.
Don't know what's wrong with ben's tjet..
Here in Greece there are many tjets with vl36 running @1.5bar overboost with the original actuator.
Ben have you checked the actuator's spring??
If it's too light,then the car can't hold boost.
Hi there guys, ben only lives down the road from me and him and i are good friends . And i have the sensors on my car . And it made a massive and very noticable difference I have the part numbers for the three of them if anyone needs them . But i would suggest getting them as they help to hold the boost for longer and the pick up of the boost when goin into the next gear is so much smoother and better !! It's a must need i think !
Mind posting up the part numbers then? I was thinking of getting the actuator to turn up my boost a little bit but after reading this thread I guess the sensors are a better option.
If I don't get the actuator and get the sensors should I still look into getting a stiffer spring? Anyone know?
what psi of boost are you running at the moment then ?
