Old 19-12-2009   #1
Grand Punto heater fan resistor
Hi all
Not posted before
Sad to say little problem with heater fan it don't work.
It's a 1.4 active sport no aircon reg Dec 07
Checked fuses,fan motor and had connectors on and off.
Where is the resistor i've got glove box out but can't see it or do you need to take all heater box out.
On the bright side if it ever works again it will be dead quiet without all the leaves in the fan !
vulcan7
vulcan7 is offline Reply With Quote Quote
Old 19-12-2009   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Grand Punto heater fan resistor
Quote Originally Posted by vulcan7 View Post
Hi all
Not posted before
try sticking it on speed 4 if it still doesn't work its likely to be the motor is kaput (4 bypasses the resistor pack)
get a multi meter and see if you have a voltage at the plug that goes onto the motor
Massive gash
Just a little touch up
Old 19-12-2009   #3
Thanks for quick reply Andy.
Put meter on and top speed it's 1.69 volts and reads about same on other speeds.
This afternoon I had fan motor out gave it 12 volts and it jumped off the step ladders so think thats working but I won't be doing that trick again.
No feed when fan switch is in off position of course.
vulcan7
Old 19-12-2009   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
resistor in to right of fan motor.
please do a search for resistor in this section as it has been talked about and documented many times before.
Old 19-12-2009   #5
Moderator
Andy Monty's Avatar
Massive gash
Old 19-12-2009   #6
Thanks for all your help everyone.
Hope to have another look tomorrow if weathers not too bad.
If no joy then it's a visit to a Fiat dealer.
Any recomendations for one in or near Wigan.
Chorley Fiat Blackpool supplied but it's a bit to far.
vulcan7
Old 19-12-2009   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
just look for melted/burnt wiring at resistor, you will see it easily enough.
p.s. resistor is near where passengers toes would be if they had legs stretched out
Old 20-12-2009   #8
If I'm looking at right thing in a white plastic housing with multiplug on that has five connectors green n yellow, green n black, blue n red, plus two thick wires that go to heater fan, should be one brown, one orange but on close inspection in between snow showers I have two brown going into connector so yes orange wire is burnt at end.
Still looks good enough to do job or does it mean I have problem somewhere else or bad connection in multiplug to resistor, how do you get resistor out ?
vulcan7
Old 20-12-2009   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
take multiplug off (press in clip and pull) and look at the end of it, are the terminals clean or black and burnt?
Old 20-12-2009   #10
Just took multi plug off again and it looks perfect checked it with mirror and torch.
It's snowing again, every time I go out it starts better get this fixed or else your all going to get lot's of snow.
vulcan7
Old 21-12-2009   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
good...wont be able to get to work tomorrow
Old 22-12-2009   #12
Lucky me I got sent home today at 1.30 pm but back in tomorrow but it was snowing
so still got a Punto with out any puff in the fan !
vulcan7
Old 24-12-2009   #13
Back on the road with working fan on all speeds, yes it was bad connection on orange wire to resistor. Not the best bit of electrical design big thick wire with cheap little connectors. Then to put multi plug it in a place that's going to be kicked when front passengers stretch out their legs.
Top tip when checking multiplug by waggling make sure engine is running as I think relay don't power without engine running.
vulcan7
Old 25-12-2009   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
stretch their legs! if they are that comftable they should buy their own car.
its ignition (+15) controlle3d, engine not need to be running,thats citroens that are like this.
Old 26-12-2009   #15
I stand corrected Mr T now only give lift's to dwarf's and make sure they don't stretch out but it's still not the best bit of design
vulcan7
(T) heater resistor paul brava Doblo 0 23-11-2009 17:44
(T) heater motor/resistor pack MK2 Punto hitherematey Punto (Mk2/2b) 6 07-04-2009 06:39
(T) Access to heater fan resistor Greg Ledder Multipla 0 06-04-2009 16:55
(G) Mk1 punto heater resistor Laurafoxy2005 Punto (Mk1) 5 17-02-2009 17:18
