Was doing a bit of preventative maintenance on the GP today, cleaned all the s***e sticky spray grease off the terminals and posts, reconnected and covered liberally with copper grease
Question is the battery doesn't look like a sealed for life battery, I unscrewed one of the cell caps and it had a dipstick type affair with a green ball on the end.
I'm assuming green means it's wet, should I be checking the other cells regularly or not
Battery is the original VARTA.
