Why can't anyone spell warranty
Because you are doing it after the valve so as far as the car is concerned it still working as it should. After the valve it makes no difference to the car if it gets dumped into the atmosphere or induction.
If you are going to fit an aftermarket one then you do it after the standard one hence why it is pointless
Reason there maybe problems is because the standard recirc is connected to the ecu, so disconnect this and the car thinks its broken.
If we all talked the same there would be no excitement in the world. :yuck:Why can't anyone spell warranty
LOL good point I'm always over-thinking thingsDoubt it. Would just buy a BOV and fit it after the recirc.
I already have to change the stock DV as I am getting compressor surge because the valve is either faulty or broken, chances are I have to pay a generous sum for the Fiat valve so I may as well get one that sounds better.
Yes it's under warentee but I'm just interested in the aftmkt DV.
If it's under warranty- you pay nothing.
Have a look at the standard recirc valve. It's not like a conventional valve where it runs off a separate pipe from the charge pipe- it's bolted directly to the pipe so an aftermarket valve would involve a bit of fabrication to fit, for very little gain.
Also, bear in mind that if you decide to disconnect the recirc pipework you need to blank-off the return to the turbo intake- otherwise you're drawing in dirty air.
Forge DV004,SpitR and Bailey DV26D are ok.
Just don't disconnect the stock recirc valve.
SpitR can work as recirc or atm.
The others are only atmo.
You remove the black flexible hose that goes from the black intake pipe to the recirc valve and you connect there your new bov.
Yes you need vacuum hose ofcourse.It's easy to find.It's a thin hose left of the bov on the manifold.It's a bit hidden under the engine cover.
I can upload some fotos if you don't understand where exacthly the hoses are.
Be careful with the cheap SSQVs.There are many fakes around...
Also as I have told you some time ago SSQV is bolt on and would need an adaptor in order to fit it.
Yes I think I could fine an adapter or make one this one looks easy enough, is this how you said I should set it up? The pic is about halfway down the page..
https://www.fiatforum.com/grande-punto/177107-weird-engine-clip.html
Better yet here : https://www.fiatforum.com/attachment.php?attachmentid=56599&d=1232309542
Ok cool and this SSQV doesn't affect the engine management light if the Stock DV is left alone? :slayer:
