Technical 1.3 multijet technical
billakoss
hi
it knows no what wears the car that is to say in pistons, turbo ...
what make they is also up to sums irrationally it can they bear
thanks
LOL Online translation? from what language? Post what you want to say in your language as theres quite a few multi-lingual folk on here who may translate.
Seems like you want to know about stresses and tollerances of components of the 1.3, is that to know how far to go with remapping?
I want to learn sum they bear the mechanic parts of engine because I want to change turbo
i want to know the characteristics of the engine 1.3 because i want to change turbo and i dont know if pistons can afford so much pressure
Θελω να δω τι φοραει ο κινητηρας γιατι θελω να αλλαξω την τουρμπινα και θελω να μαθω για την αντοχη του , τι πιστονια φοραει , και γενικα οτι εχει σχεση με το μοτερ.. και μεχρι τι πιεση μπορει να αντεξει μαμα
where are our Greek friends, theres at least 3 of them in GP section:confused:
My mate Dino translated this for me.
I'd like to see what's in the engine, because I want to change the turbo and I'd like to know how much it can withstand (i.e. endurance), what sort of pistons it has, and generally I'd like to know everything there is to know about the engine... and up to what sort of pressure it can withstand (not sure pressure is the right word, as I don't know much about car terminology in either language).
have a look at my previous posts, i wanted to tune my 1.3, but the 1.3 is limited wth its ecu. i think it was tris recomended a corsa 1.7 diesel turbo. a remap can be done, but it wioll only add at maximum 25bhp. tmc do a tuning kit, which is 115 pounds that had good reviews, im considering it for after christmas.
billakoss if you manage to sucessfully tune your 1.3 let me know!!
The word 'tolerance' might be more appropriate than pressure, methinks.
It is to my understanding that Bilakoss has realised he cannot remap the 1.3JTD, hence he wants to fit a larger turbo, all he needs to know is what sort of tolerances will peripheral components take, should he go ahead. For example, if he fits a larger turbo, will the pistons cope? Will the gearbox take the extra torque, and if so, how many lb/ft (or Nm, lol) will it take before going bang? If he replaces the turbo, what sort of extra work will the car need in order to take the extra power in a reliable manner?
I feel only an engineer from Fiat or somebody who's very knowledgeable about the 1.3JTD engine will be able to give some advice here, although my advice to Bilakoss is to simply sell his 1.3 and buy the 1.6JTD or the 1.9JTD if he is not that bothered with the mpg difference.
Bilakoss, Από ότι βλέπω θέλεις να μάθεις τις ανοχές εξαρτημάτων σε περίπτωση που αποφασίσεις να αλλάξεις την τουρμπίνα της μηχανής. Ο κινητήρας 1.3 από όσο ξέρω, δεν μπορεί να χαρτογραφηθεί, αν ήμουν στην θέση σου και ήθελα ένα πιο γρήγορο Πούντο, θα αγόραζα το 1.6JTD ή το 1.9JTD, έστω και με αυξημένη κατανάλωση. Το δικό μου 1.9JTD καταναλώνει από 5,5 έως και 6,5 λίτρα ανά 100χλμ, εκτός αν διανύω μικρές αποστάσεις εντός πόλης, οπότε και η κατανάλωση εκτοξεύεται στα 7 λίτρα ανά 100χλμ. Ελπίζω πάντως κάποιος στο φόρουμ να γνωρίζει τις ανοχές των εξαρτημάτων της μηχανής και να μας ενημερώσει σύντομα. Στο μεταξύ, γράψε μας τί τούρμπο θέλεις να περάσεις στο Πούντο σου, ούτως ώστε να μιλάμε με συγκεκριμμένα στοιχεία και όχι με εικασίες.
Ελπίζω να σε βοήθησα κάπως...
