Need a bit of advise, my front suspension is knocking so I replaced both the droplinks but it is still doing it. Is there anything else that could be causing it?
mines knocking and its my top mounts that have died but i cant get them on warranty due to sportlines . is yours lowered and how would you describe your knocking?
No not had It lowered, it's like a metal knocking sound just on the passenger side, very noticable when going over bumps/potholes. Thought replacing both droplinks would cure it as that's what I found searching the forum.
Ffoxy
the warranty ran out in march, I'm just bewilderd at what it could be as it's only on one side.
I had this problem, my local dealers changed the drop links but didn't make much difference. They kept saying nothing was wrong then eventually the front n/s spring snapped and the o/s had a crack in it. They were replaced under 3rd year warenty.
I had this and it was a track rod end. As Ffoxy said, it's best to let the garage sort this on. The process of elimination you are taking could be quite costly! Hopefully it won't be that expensive
It may be something quite simple like the air filter box loose where it attaches to the body.
Mine was knocking after a service, and i had visions of having to spend lots of money sorting it out.
but it turned out to be a perished grommit on the air box.
