Technical Tail light problem
Norfolk
Hi, the bulb warning light came on my dashboard and I discovered that the drivers side rear brake light wasn't working at all.
I changed the bulb with the correct one but now I have the following...
When headlights are on dipped the drivers side rear red light (bottom one of the three) is always really bright. When I brake the left hand one comes up to the same brightness as the right hand one. So on the right it is as if you are always braking.
When the headlights are not on it functions correctly with both lighting up to the correct level.
The warning light has not gone away!
Any ideas?
Still under warranty so guess I can go to dealer if it is electrical fault.
Any ideas?
how did you get on with problem?
thanks
