Didn't think of asking for the code! The mechanic did say there was a chance it might be out of date to the codes Fiat use now and advised me to go to Fiat and let them have a look. The check engine light has now been switched off and i have driven the car without putting it under too much load and the light has stayed off.
Do you think the K&N panel filter may be causing it? is is worth doing a few hundred miles to see if the ECU can adjust? Either way i will book it in with Fiat today, i have a creaky seat i need sorting anyway!
