General rear fog light
les80
manchester
Could anyboby offer advice on how to remove the rear fog light for bulb replacement. I've look in the handbook but it is no help at all.
Thanks in advance.
one would assume its a grande punto ;)
ideally you need to jack and axle stand the car at the back corner you need to be under it to make it easy although it can be done without....
once you can get your head and arm under locate the wire running to the back of the lamp or use a torch...
where the wires go in that is the back of the lamp
there is a set of plastic tabs...
unscrew this anti clockwise about 1/3rd of a turn (its a 3 leg bayonet type fitting)
then pull
now you have got to the bulb
replace (its a normal car 21 watt bulb iirc)
put a smear of vasaline on the O-ring seal to aid it seating
locate the 3 pins back into the recesses then push in and turn clockwise (y)
