when i start the car the usual glow plug light flashes up i wait for it to go out and turn the ignition over and she starts the very first time... then i get the warning "check glow plugs" and the little glow plug light flashes at for a little while 5 or so times, then the message clears its self. Car runs perfectly fine too...
Any ideas? as im abit of a noivce were are the glow plugs so i can check them.. assume its just a loose connection? might have knocked them when i cleaned my egr valve out today? if there located around the same area.
an going to disconnected the battery in the morning to try and reset the ecu see if this clears it? but if anyone can point me in the direction as to what im looking at for the glowplugs that would be greatly appreciated so i can check all connections?
