Thread Tools
Old 12-09-2009   #1
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
forge braces on 1.9 multijet
fitted my forge braces today, and it looks like im second person with problems,
when you put your foot down, it vibrates like hell, its the larger of the two braces either catching on the exhaust or bottom of gearbox, yet when the car is stationary and you look under, the brace seems pretty far away from either of the two!!! :-(
any one else with the diesel had these fitted
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 12-09-2009   #2
Re: forge braces on 1.9 multijet
i have fit them to my T-jet and there fine. no problems it drives like a dream.
mike coldnose hotchin is offline Reply With Quote Quote
Old 12-09-2009   #3
Top Dog
Tris Harris's Avatar
Trader Rating: 1
Tris Harris has donated!
i cant even fit them on mine because Fiat decided they wanted to be inconsistent with exhaust hangars
Tris Harris is offline Reply With Quote Quote
Old 13-09-2009   #4
puntopower!
Trader Rating: 6
Angry Re: forge braces on 1.9 multijet
new bigger problem, now there fitted, after a minute of drivin the dash beeps and loads of messages and warning lights come up:
ebd failure
no hill holder
no abs
no power steering?!?!?
how the hell can fitting braces cause this??
the only other thing i did whil i was fitting these braces was fit 5mm hubcentric spacers on the front wheels. could this cause this?? im soooo confused!
Old 13-09-2009   #5
rosshutchie has donated!
I actually just got round to fitting them this morning. Had them in my garage for months but got use of my next door neighbours lift to change oil and filter and fit these.
I havnt had any problems yet with vibrations or anything, seems to drive a lot better.
I dont think the braces could have anything to do with those faults, maybe just coincidence?
rosshutchie is offline Reply With Quote Quote
Old 13-09-2009   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by matty_oakley View Post
ebd failure
no hill holder
no abs
CAN fault between ABS & EPS,ABS ECU/EPS ECU or more likely brake switch.
Old 13-09-2009   #7
puntopower!
Trader Rating: 6
just got my breakdonw cover guys to come check it out, and they say its because ive swapped the wheels from the back to the front ( ive got 215-45-17 on them) and he said i need to put standard tyres back on front.
Old 13-09-2009   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
you mean you have diff sized tyres f & R?
Old 13-09-2009   #9
OLZ has donated!
I do, 40profile on the front and 45 on the back - no warnings?
OLZ is offline Reply With Quote Quote
Old 13-09-2009   #10
Yeah thats quite weird. Ive had 15's on the front and 17's on rear at one stage and had no warnings at all
Old 13-09-2009   #11
i have 215/45/17 on front and rear for past 10k or so without any problems, cant see how its linked! I would say its when you've fitted your hubcentric spacers. As T has said i would bet on the brake switch, when we disconnected this a few times on the stilo it caused all hell lighting up on the dash and every now and them would cut power from the car sending it into limp home mode. 30 quid later for a new switch and all was good? They are so sensitive..
Did you fit the spacers for clearance, cause i havent had any problems with wider tyres? Have you changed ur bolts now? are they long enough now you've got the spacers on?
Or have you not tightened them enough, causes vibrations when driving - i know ive done this when in a rush and forgot to tighten them properly. Just problem shooting in my head.. Would probaly be the bolts not being long enough now uve got the hubcentric spacers? and i bet the brake faults are the brake switch sensor
1.8Stilo is offline Reply With Quote Quote
Old 13-09-2009   #12
puntopower!
Trader Rating: 6
Quote Originally Posted by T14086 View Post
yes T, at the time i needed new tyres there were no 205-45 tyres in stock so i opted for 215-45 and put them on rear, and 215 40 17 on front, and yesterday i swapped them all round.
update:
all warning lights have gone, i just disconnected battery for ten mins, then reconnected and went for a spirited drive. sorted :-)
Old 13-09-2009   #13
are you still getting a knocking from the braces? catching on the gearbox or exhaust?
Old 13-09-2009   #14
puntopower!
Trader Rating: 6
Quote Originally Posted by 1.8Stilo View Post
yes its catching on gearbox lower mount under full throttle! :-(
Old 14-09-2009   #15
Thats really weird, i havnt heard mine rattle or vibrate once and ive done about 100 miles with them fitted. Can you feel the vibration through the car?
Thread Tools
(G) Forge Subframe Braces puntomatic Grande Punto 7 03-09-2009 18:51
Hello from Forge Motorsport Forge Motorsport Newbie Central 3 23-01-2009 13:22
