General Breather pipe
Tristania Dream
Leeds
Would anyone know the internal diameter of the breather hose on a GP 1.2 8V. I'd go have a look myself but I'm waiting on delivery of a pair of right angle pliers so I can get the clips off.
Once the engine is warm i could just pull the pipe of the engine 1.2 8v
let me know what you find,
if you would be so kind,
only if you do not mind,
hang on i think this rhymed.:D
just had pipe go next 2 oil cap go and small one of air box second time so put on 5mm petrol hose on small one and 16mm heater hose on big one workes ok
I was having problems with air being pulled into system so replaced the smaller hose as it was split. I used 6mm fuel hose and works great. Was still getting a bit of judder from the exhaust so had a closer look at the breather hose and noticed it was cracked along the part under the filter. Will go find 16mm hose like you suggest. Just need my pliers to get clips back on afterwards. Cheers
can put new jubb clips i did.
