Ah why didnt you say that I would of started saving for one ages ago.
Can't read my language?
Good job! Do you have a dyno chart of the car?
with a bit of luck you wil lkill yourself or even worse someone else with this silly mind set you have of straight line speed you stupid ZORBA boy racer
So JASSYO leave zorba alone and be more polite next time if you dont know the facts because i can also write racist comments.Coprente
I thought you had been saying it cant be mapped, my mistake
do me peter. do me turbo when i get one. lol.
guess we geta see how much dif the forge IC makes when i come down.
did you fit the abarth turbo or the abarth esseesse turbo?? because the abarth has only 160 bhp and not 170!!Hello to everyone! I would like to say some things to all t-jet guys thinking of doing this swap.First of all the price we did the swap (vl 36) was very low (using a new turbo,not used---approx. 700 pounds with the remap which was neccesary) and thought it was a very good value for money. Well the numbers we saw were less than we expected ( 170 hp @crank) and this is because we dont have the same cams with the Abarth.The car comparing it to my T-Jet (remapped,catback) rolling side by side with 2nd gear from 3.000 rpm was slightly ahead till mid 3rd gear and ALL the difference was in 4th gear.My friends T-jet just dissapeared there ( 5 car lenghts till 190 kmh). All i can say now is that the car is side by side with a Corsa OPC (192ps) till 200 kmh. Impressive,huh?
Now i have my Abarth turbo i cab start asking a few questions! How difficult was it to fit. I understand its a direct replacement so should be a case of bolting it on using the original gaskets and hoses! Or would you recommend getting new gaskets and hoses?
