Anyone got a picture of where the puddle lights go? I don't remember seeing a plate on the door card where they would be. My car is still in the bodyshop
my friend i once used a led bulb and the light was dissapointing. it didn't illuminate much so i hooked back the original one. maybe you should reconsider using led for the interior light. not very bright. except it has like 40 leds on it.
Do the LED's dim then with the interior light? I didnt think they would, as to dim an LED, it is not a voltage change that is required but a frequency change in the current?
I cant wait to see all this done, its gonna look class
What are you proposing to use for interior lights for the rear passengers just out of interest? I've thought about it but struggled to find actual covers (by this i mean cover over the bulb) that would look good. Unless i rob some from a beemer in a scrappy or something.
But, all this lighting, will it not put too much strain on the interior light circuit?
How do you get at the sidelight wiring? I'd like to do that actually...
I doubt its as simple as my mk2, new where everything was in that lol
can someone reprogram the body computer in order to read low power consumption so if you put led bulbs it would not read burnt bulb thus eliminating the need of a resistor?
