well its just under 20psi at the moment, but it has its moments because in 2nd gear sometimes the limiter does not cut in and its pulls reallly well and u get a load of torque steer thrown in with that lol
more than likely, from what peter and red dot have figured out, it seems there is an embeded code that doesnt allow the abarth turbo to be mapped to the ECU that the t-jet runs.
but from what i know, the t-jet, abarth and esse esse use the same ecu iirc.
how can it go bang when its all limited?? and im not quite sure what you mean about the raggazon de-cat?? but it runs fine with the de cat on it though that engine management light is just to tell you that your cat is not working as good as it should so it will not effect the power on that side of things
Thats the boost limiter cutting in and, sorry for bad vid i was trying to drive at the time and its more towards the end because i need a straight bit of road lol
