i have a 2008 t jet, and had a small knock on the passenger wing. now on the info screen it reads "fuel cut-off" and the car wont start. does any1 knw where the switch is so i can reset it
open the door wide bend down, on the plastic trim on the accelerator side there is a gap between the dashboard and the lower trim slide your hand in the gap there is a rubber tit in the hole on the lower trim press that down
tried that cos i had a 2006 and it was there. but now on this new t-jet model its not there. i even took off the plastics in the footwell...the rubber tit insnt there...fiat told me i need to book it in and pay 120. jus for a reset....which jus takes 10 mins and i fint that unresonable....im sure its in the cockpit some where
apparently theres no switch and needs to bee done on a pc....put my car isnt startin cos of it and fiat are charging an arm and a leg.....some 1 said i need to change to fuel relay first.....i called n a specialist yesterday and he connected his device and read and reset the faults but the fualts came up but then said they cant be deleted...im STUCKKKK!!!!
