Does anyone know where to buy an upgraded/uprated clutch for Mjet?
Beany_bot is back...!
Clutch is on a dual mass flywheel mate, dont know if that makes a difference. I see Valeo mentioned regularly in Fiat Performance clutch queries but I dont know if they do one for the GPS MJet yet. How the feck have you broke or worn yours out? How many miles you done bud you must have ragged it to death! I got 45,000 miles on mine now and no hint of slip or judder and bites half way up the pedal stroke still....
Yep its a goner. Damn italians. Could just replace it but rather replace it with a better part.
Not damn Italians mate.... fairs fair, have you been drag-starting and riding the clutch, I do need to know donchaknow! As I said mine is fine, oh and I started a Re-mapped MJet Social Group in here if you want to join us?
As for the turbo oil feed pipe, didnt your dealer have that off doing checks and stuff a bit back? Poor fitting IS a "damn Italians" case from manufacture but not if a "damn Scots" mechanic foobarred it for you!
That could have been terminal!
Aye, the Red Dot guys responded to my "I don't wanna fry the clutch each time I pull away comment" with - "Nah, these are good mate, never had a problem with ours, they're really strong"... So you must be giving it some!
dont matter if you drive it hard when he clutch is engaged.
all the wear happens upon contact and release. Clutches are supposed to last a very long time, pre-mature wear is normally allways driver error.
he may not know he is slipping the cutch as the dual mast flywheel can hide a bit of slippage due to the way it operates.
but yes, ive never been through a clutch.
as an example, my cousin passd his test 3 weeks ago, got a brand new clio1.2 tce thingy. needs a new clutch already. purely down to driver error.
Try www.clutch-specialists.co.Uk heard good things bout them, guys with remapped Stilo jtd's and mk II puntos use there performance clucthes. Meant to be really good and they listed about every fiat - well most cars! Will prob need to ring them as when I was looking GPS mjet wasn't there but they can supply one if you ring them... Was while ago! If not try GSR
Fair enough, could be driver error, allthough ive never knowingly ridden the clutch. Driven 160k on my last car never needed a new clutch. Strange. Few people have told me increased torque can put alot more strain on the clutch?
increased torque can induce excess wear.
but you should have adjusted your driving style to suit.
hows that then?
