im Axle Specialists
Thread Tools
Old 18-03-2009   #1
Greece
Blow Off Valve multijet 1.3
hi
I want to put blow off valve in grande punto multijet 1.3 other I do not find that should it enters precisely if has somebody photo would help me
thanks
billakoss is offline Reply With Quote Quote
Old 18-03-2009   #2
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
Re: Blow Off Valve multijet 1.3
You cant its a diesel. They dont like BOV's.
punto_matt is offline Reply With Quote Quote
Old 18-03-2009   #3
Greece
Quote Originally Posted by punto_matt View Post
that is to say it does not enter they is not good for the car
Old 18-03-2009   #4
Banned
punto_matt's Avatar
Western Samoa
Pardon?
Old 18-03-2009   #5
Greece
it does not enter in auto or they is not good for the car
...Sorry im dont speek good english
Old 18-03-2009   #6
Banned
punto_matt's Avatar
Western Samoa
They arent good for the car. Deisel engines shouldnt have a BOV on them.
Old 18-03-2009   #7
Greece
ok thanks¨)
Old 18-03-2009   #8
Greece
sorry for this...
Εννοει οτι ειτε βαλεις σκαστρα ειτε οχι ενα κ το αυτο.Ο common rail κινητηρας δεν συνεργαζεται με σκαστρα.Βασικα υπαρχουν στο forum αρκετα θεματα με σκαστρα για ντιζελ.Στο λεω γιατι ηθελα κ γω να βαλω αλλα δυστυχως...Νομιζω οτι με ενα βαρελακι η μια χοανη κατι μπορει να ακουσεις αλλα δεν ειμαι σιγουρος και για το αν το τελικο αποτελεσμα θα ειναι καλο ακουστικα!
I've just told him in Greek about BOV in diesel engines.
Ok, curry on...
vagosofron is offline Reply With Quote Quote
Old 18-03-2009   #9
just can't get enough
toad101's Avatar
toad101 has donated!
you can fit one to a diesel but they have to be electric and their not cheap
http://www.ricambituning.it/en/produ...?id=483&cat=45
toad101 is offline Reply With Quote Quote
Old 18-03-2009   #10
Banned
punto_matt's Avatar
Western Samoa
Not really a proper BOV then.
Old 18-03-2009   #11
toad101's Avatar
well their basicly a normal bov with a switch added because a diesel doesn't have a throttle body which closes when you lift off causing a massive pressure build up which forces the spring up and opens a normal bov
Thanks Tym thanked for this post
Old 19-03-2009   #12
F/A-18 Hornet Champion
a bov is actualy vacum operated. a feed taken from the inlet manifold which can tell there is a build up of pressure which in turn operates a valve which vents the air to atmosphere or re-circualtes.
clawliger is offline Reply With Quote Quote
Old 26-02-2013   #13
Australia
why on my Grande Punto 1.9 Diesel got a "whooosh!" sound everytime i release my accelerator pedal, if no BOV on Diesel? wheres thats noise come from?
Grande Punto MJTD 1.9, 6speed
leomalagueno is offline Reply With Quote Quote
Old 26-02-2013   #14
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
The noise comes from the wastegate or surge back through the Turbo.
ChrisUK is offline Reply With Quote Quote
Old 26-02-2013   #15
Moderator
ChrisUK's Avatar
Trader Rating: 1
You running standard air filter?
Thread Tools
(Tu) Blow Off Valve on T-Jet... macaronas Grande Punto 55 27-08-2012 16:32
(T) blow off valve 2shae Punto (Mk2/2b) 0 09-11-2008 15:22
(T) blow off valve issue ? psychofant Grande Punto 4 12-05-2008 11:23
(T) blow off valve vassil1s Grande Punto 1 17-02-2008 21:15
(G) gt hks blow off valve thebouncer Punto (Mk1) 4 13-09-2007 15:31
