sorry for this...
Εννοει οτι ειτε βαλεις σκαστρα ειτε οχι ενα κ το αυτο.Ο common rail κινητηρας δεν συνεργαζεται με σκαστρα.Βασικα υπαρχουν στο forum αρκετα θεματα με σκαστρα για ντιζελ.Στο λεω γιατι ηθελα κ γω να βαλω αλλα δυστυχως...Νομιζω οτι με ενα βαρελακι η μια χοανη κατι μπορει να ακουσεις αλλα δεν ειμαι σιγουρος και για το αν το τελικο αποτελεσμα θα ειναι καλο ακουστικα!
I've just told him in Greek about BOV in diesel engines.
Ok, curry on...
well their basicly a normal bov with a switch added because a diesel doesn't have a throttle body which closes when you lift off causing a massive pressure build up which forces the spring up and opens a normal bov
a bov is actualy vacum operated. a feed taken from the inlet manifold which can tell there is a build up of pressure which in turn operates a valve which vents the air to atmosphere or re-circualtes.
Ive been getting the same in my 1.6 punto diesel recently. It normally has a little whistle when it spools but if I lift off around 1500 or slow my engine down fast by dipping clutch etc it makes a flutter like a wastegate. Now is this backpressure in the turbo creating the choppy sound or is it a wastegate? Hearing the noise at 1500rpm from just lifting off lead me to think wastegate but I didnt kno if the car had one or was just a recirculating bov. Thanks.
