Old 08-03-2009   #1
Engine Oil & Gearbox Oil
Im mid way between services now and im due to do a track day soon so I want to do an oil change. not sure what engine oil to use though, Im tempted to just go to Fiat and get 5 litres of Selina but I can see it being cheap, and for the money I could get something from the more recognised oil makers
as for the gearbox oil..... is it easy to change, I really really think the level in mine is low, it nearly always gives a big clumk or grind into 2nd when its cold, and more recently ive noticed it doing it while its warm too, where is the filler and the drain plug for the gearbox oil?
Mattyk is offline Reply With Quote Quote
Old 08-03-2009   #2
amcand has donated!
Re: Engine Oil & Gearbox Oil
Which engine do you have?
amcand is offline Reply With Quote Quote
Old 08-03-2009   #3
its the 1.9 M-Jet Probably should have mentioned that :P
Old 08-03-2009   #4
do the dealers never check 'box oil at services?
OCZedd is offline Reply With Quote Quote
Old 08-03-2009   #5
I dont know, mine doesnt feel all that fresh
Old 08-03-2009   #6
same i dont think they do tbh
Old 08-03-2009   #7
Quote Originally Posted by Mattyk View Post
if you check under your bonnet , on the sticker that is there it gives you a recomendation... mine says
Quote Originally Posted by Sticker
Engine Oil - We reccomend that you use oil
Hope this helps
sp!n is offline Reply With Quote Quote
Old 08-03-2009   #8
Haha Ive noticed that!
Old 08-03-2009   #9
what else you going to use? WD40? LOL
(G) Gearbox oil. ep 80w/90 hypoid gear oil? sassbs Bravo / Brava 1 21-04-2008 09:36
(T) Oil additives in engine or gearbox? combwork Multipla 0 04-10-2007 02:50
(G) Gearbox Oil & Cv problems HELLBOY787 Panda (Classic) 13 16-12-2006 02:35
Gearbox oil drain plug & rear brakes hangten Car Care 1 28-08-2005 17:06
(T) Gearbox oil type & plug key size ? stoopid_name Bravo / Brava 5 22-10-2004 17:53
